RobT5M Posted May 8, 2022 Report Share Posted May 8, 2022 ITS BACK!!! So what broke this time? 1 Quote Link to comment Share on other sites More sharing options...
Zappo Posted May 8, 2022 Report Share Posted May 8, 2022 An update I suspect. We have had the same issue in the past, but only for a day or so. Quote Link to comment Share on other sites More sharing options...
RobT5M Posted May 9, 2022 Report Share Posted May 9, 2022 11 hours ago, Zappo said: An update I suspect. We have had the same issue in the past, but only for a day or so. Makes sense. Quote Link to comment Share on other sites More sharing options...
gmsgltr Posted June 8, 2022 Report Share Posted June 8, 2022 how often do you kids replace your control arms on your p80 AND with what? Lemforder is the OE right? Its the only thing in my entire suspension that I havent replaced as of late in years (its been done back in the day) and I still have loose steering on the highway (maybe its the 'toe'?) and what hurts the most is some noises/clunk on small low speed bumps (axles are relatively new too - raxle axles in fact) Quote Link to comment Share on other sites More sharing options...
Zappo Posted June 8, 2022 Report Share Posted June 8, 2022 They are relatively cheap to replace, so do it. If the toe has gone neutral, the car will wander more than if there is the normal slight toe in. Toe alignment issues will case excessive tire wear. I replaced mine in December because of toe issue, and the rear bushing on both were worn out. I am on my 3rd set since owning the car, but I do have a lot of miles on it. Quote Link to comment Share on other sites More sharing options...
Brad850 Posted June 8, 2022 Report Share Posted June 8, 2022 Greg I have the same problem on my white R and I beleive it to be the steering rack unfortunately Quote Link to comment Share on other sites More sharing options...
gmsgltr Posted June 9, 2022 Report Share Posted June 9, 2022 i think its my rack too - i need to purge/replace fluid to start i just had a pretty lengthy alignment at a local shop after re-doing the entire suspension with coilovers... my alignment, to me, is fine only things that arent new are the control arms and tie rods (but they have less than 20kmiles but are probably 10 years old) 1 minute ago, gmsgltr said: i think its my rack too - i need to purge/replace fluid to start i just had a pretty lengthy alignment at a local shop after re-doing the entire suspension with coilovers... my alignment, to me, is fine only things that arent new are the control arms and tie rods (but they have less than 20kmiles but are probably 10 years old) and to add - the steering is only super loose on highway - i can make minor adjustments with the wheel and nothing happens. my buddy said to adjust toe to see Quote Link to comment Share on other sites More sharing options...
gmsgltr Posted June 14, 2022 Report Share Posted June 14, 2022 in the process of buying new ipd front sway mounts/poly bushings - mine are plenty old enough and have never been re-lubed Quote Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted August 7, 2022 Report Share Posted August 7, 2022 Quote Link to comment Share on other sites More sharing options...
Zappo Posted August 8, 2022 Report Share Posted August 8, 2022 I want to see it launch Tie Fighter drones. 1 Quote Link to comment Share on other sites More sharing options...
gdog Posted January 3, 2023 Report Share Posted January 3, 2023 On 6/14/2022 at 1:24 PM, gmsgltr said: in the process of buying new ipd front sway mounts/poly bushings - mine are plenty old enough and have never been re-lubed Last time I installed mine I added zerk grease fittings so never have to R+R to lube them again; did it to both cars; works well. Quote Link to comment Share on other sites More sharing options...
gdog Posted January 3, 2023 Report Share Posted January 3, 2023 Off topic from volvo: Anyone have experience with audi B8.5 S4 cars? B8.5 S4 ran from 2013 to 2016 MYs. Quote Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted January 3, 2023 Report Share Posted January 3, 2023 12 hours ago, gdog said: Off topic from volvo: Anyone have experience with audi B8.5 S4 cars? B8.5 S4 ran from 2013 to 2016 MYs. 👋🏻 Resident Deuthchbag here Quote Link to comment Share on other sites More sharing options...
gmsgltr Posted January 24, 2023 Report Share Posted January 24, 2023 how does carfax work these days - anybody on here with the hookup? Quote Link to comment Share on other sites More sharing options...
Brad850 Posted January 24, 2023 Report Share Posted January 24, 2023 7 hours ago, gmsgltr said: how does carfax work these days - anybody on here with the hookup? I'll fuckin do it babe. I'll car fax anything. I'll car fax you how do ya like that?? 3 Quote Link to comment Share on other sites More sharing options...
