andrew_the_fox Posted October 5, 2007 Report Share Posted October 5, 2007 Hey guys, I just scored a cheap 19t, with a downpipe, and I'm planning on installing it over the summer, what else in terms of performance parts should go along with it? I want to basically know what should I do alongside the 19t to keep everything working well under the hood of my car? Link to comment Share on other sites More sharing options...
ViperVette Posted October 5, 2007 Report Share Posted October 5, 2007 RICA Link to comment Share on other sites More sharing options...
Dmsee Posted October 5, 2007 Report Share Posted October 5, 2007 ECU tune Link to comment Share on other sites More sharing options...
Karlson Posted October 5, 2007 Report Share Posted October 5, 2007 is it used 19t? Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted October 5, 2007 Report Share Posted October 5, 2007 you are gonna need more rods. Link to comment Share on other sites More sharing options...
ViperVette Posted October 5, 2007 Report Share Posted October 5, 2007 ... Just go with RICA, have them custom map it. Also, do a FMIC and/or Aquamist. Doubt your going to need to actually build anything. Maybe a valve job up top if you want to get some higher #s. Link to comment Share on other sites More sharing options...
andrew_the_fox Posted October 5, 2007 Author Report Share Posted October 5, 2007 is it used 19t?Yes, lightly used through a good friend.you are gonna need more rods.I hope not, I'm waiting a while to install so that it can be done right and hopefully avoid thatSo it looks like I should start witha tune than? Link to comment Share on other sites More sharing options...
Boost3237 Posted October 5, 2007 Report Share Posted October 5, 2007 Yes, lightly used through a good friend.I hope not, I'm waiting a while to install so that it can be done right and hopefully avoid thatSo it looks like I should start witha tune than?injectors and tuning. dont floor it unless your @ 4krpms or higher if you are boosting more than .3 bar do that and you should be mostly set. Link to comment Share on other sites More sharing options...
ozzimark Posted October 5, 2007 Report Share Posted October 5, 2007 injectors and tuning. dont floor it unless your @ 4krpms or higher if you are boosting more than .3 bar do that and you should be mostly set.and why not? the stock configuration should be making quite a bit more boost than that at less RPM. the difference in exhaust restriction shouldn't be making THAT much more torque that you have to worry about bending rods :ph34r: Link to comment Share on other sites More sharing options...
andrew_the_fox Posted October 5, 2007 Author Report Share Posted October 5, 2007 I made a list of a whole bunch of things I was thinking about doing but I have no clue what order to do them in, and I doubt if I'll be able to afford every single one of these things so after going through my list I came up with the abridged version of what I hope to have complete by the end of Summer 2008.Under the Hood19tRICA TuneFMIC KitTransmission CoolerHeat Wrap PipingBigger Injectors (unsure what size)Fuel Pressure RegulatorExhaustS60R Exhaust ManifoldFull 3'' Exhaust CatlessSuspensionKoni Adjustable StrutsQBM HD EndlinksEventually5 Angle Valve JobUnorthodox Racing Underdrive PulleyAquamist SystemOil CoolerWiseco OS2 Forged Pistons RSI Forged Rods Link to comment Share on other sites More sharing options...
Boost3237 Posted October 5, 2007 Report Share Posted October 5, 2007 and why not? the stock configuration should be making quite a bit more boost than that at less RPM. the difference in exhaust restriction shouldn't be making THAT much more torque that you have to worry about bending rods yes you are right the STOCK config. can produce .3 bar or higher in lower rpms. and that is because of flow characteristics and its not the exhaust but the angled flange the 19T has will make it spool faster and induce a MUCH larger amount of torque over a shorter time span through the power band then a STOCK 15G or 16T and withough proper timing and fuel you will nuke your motor quick fast and in a hurry. that said, with a 19T don't floor it over 4krpms (ive been boosting 19-22psi for 2 yrs on a 19 tune with orange injectors) and have been fine with going WOT @ 4k-4500rpms. if you wanna take a chance and floor it sooner with a turbo KNOWN to bend rods, you can do so. Link to comment Share on other sites More sharing options...
ozzimark Posted October 5, 2007 Report Share Posted October 5, 2007 so to put it simply, it's the surge you have to worry about and i wasn't saying floor it earlier, i was just questioning the 0.3 bar number you put up there. that's hardly any pressure :arob: Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted October 5, 2007 Report Share Posted October 5, 2007 ask mike how his 19t is working out for him. Oh yeah, he blew his motor in two weeks. Before you put it on, make sure you have an extra engine, or the money and time for a rebuild. Link to comment Share on other sites More sharing options...
Karlson Posted October 5, 2007 Report Share Posted October 5, 2007 Yes, lightly used through a good friend.I hope not, I'm waiting a while to install so that it can be done right and hopefully avoid thatSo it looks like I should start witha tune than?a suggestion, don't wait a year for a used turbo. I waited almost a year too to install used turbo, after installation the seals start leaking in a week. if you are installing used 19t, then do it know, or get ready to rebuild it. Link to comment Share on other sites More sharing options...
andrew_the_fox Posted October 5, 2007 Author Report Share Posted October 5, 2007 Well if I buy it and put it on immediately what can I do to be sure I don't boost f.uck myself like what happened to a few other forum members?I can't afford a tune or any of that right now, if I put it on and keep the boost low will I be alright? If so, what boost should I aim for? Link to comment Share on other sites More sharing options...
