What Did You Do To Your Car Today.
scout01
  • Replies 24.9k
On the 95:
  • Pulled the carpets & foam out to dry before heater core replacement.
  • Pulled the DS door card to replace lock cylinder, realized I didn't need to do that, found my window track in the bottom of the door
  • repaired DS lock cylinder
  • installed Greddy turbo timer
  • adjusted SC901 mounts so it locks into place
  • Found my brake fluid leak
  • Fixed the speedo after M56 swap
  • removed DS door lower weatherstripping (to be replaced)
  • Removed center console damping weight (might put it back in)
On the V90:
  • Looked at it
Got rid of the drug dealer wheels. Now for the moar low part... and maybe a wash and detail.
Wash/detail it and drive it. Don't lower it unless it's on air. I remember trying to get into your parking garage. Plus, you don't need two super-low race cars.
On the 95:
On the V90:
  • Looked at it
Moving right along on that car! Local shows won't be the same without the V90. :(
...Da Fuk I don't! :lol:
you know what you must do right......
That is a bit extreme imo, but I do plan on a complete exhaust. Already found race cats, and a rear silencer that is +9db louder than stock, with better flow characteristics, and removing the suitcase muffler. Just need to finish the V70R first.
I have bare metal on a section of my D2's and they've been on the car since 2011 IIRC. Every time I look there is barely a hint of surface rust.
Koni's rust. It's what they do.
They do, but the sway bar rusting is BS. I'm replacing mine this week (hopefully), I have that much rust on mine after just 50K miles.
On topic: yesterday, watch a gust of wind blow a tent out of its spades and into my car. Missed the back window, and the bikes but definitely didn't miss the roof. :(
I've been looking at getting a front iPD bar, but I don't want to lose the ability to pre-load both sides
Are you currently pre-loading it?
