Brake Rebuild Guide
Che'_Moderator
QUOTE (matt b @ Dec 22 2007, 06:46 AM)
Nice! Serge, I've been quoted rebuild kits at auto parts store. I think Carquest has one for $12-$15 that includes everything you need.
Can I digg that write up ?
Wait a while. I will add a digg button probably the day after Christmas. Getting an article to the front page on a weekend makes baby Pyrrhus cry.
Rebuilding the calipers use to be part of the "premium" brake job when i worked at midas. Pads, turn rotors, replace caliper hardware and seals and flush brake fluid(or rebuild wheel cylinders, replace shoes, hardware and turn drums)
Absolutely great way to save some $$! Especially if you have a p1 R, where the caliper bracket is different than other models that share the same caliper. When I had my front brakes rebuilt, the rebuilt units I got back were the the ones with the smaller caliper bracket, lots of money and time wasted going back and forth until finally just having my old calipers rebuilt and given back to me. If you chose to send yours out KING KALIPER does do a fantastic job for reasonable cash.
FYI rebuilt caliper is usually 50-70 dollars. Rebuild kit is 10-15. Job takes 30 minutes tops. You will spend more time packing them up to ship the cores back. For multi-piston calipers you just block in the pistons you do not want to remove and work your way around.
One question, never did a rebuild myself. I bought exchange calipers..
Can't you insert the dust cover before inserting the cup?
You can insert it on the piston but not in the caliper groove. But getting it on the piston is not the hard part so I do not bother
This topic is now closed to further replies.
