VolvoWill Posted January 4, 2008 Report Share Posted January 4, 2008 So I was swapping out my optima redtop from my 242 into my 850 (this was at night so it was dark) I connected the battery backwards and the engine started to smoke from by the alternator. Now it does it all the time if I try and connect it. Did I fry the electronics or do I just need a new alternator? I was just wondering if anyone else has done this and If so what was the problem. I hope to see some input besides this kid is a stupid retard. Link to comment Share on other sites More sharing options...
Ronny Posted January 4, 2008 Report Share Posted January 4, 2008 Probably some insulation got melted when you hooked it up backwards. Now there's a short even when it's hooked up right. Best to get in there and have a look around for damaged wiring before you do anything else. Link to comment Share on other sites More sharing options...
lookforjoe Posted January 4, 2008 Report Share Posted January 4, 2008 You probably fried the alternator, at the very least - if it smokes when you try & connect the battery correctly, it now has a dead short. Hopefully you didn't kill the ECU's... Link to comment Share on other sites More sharing options...
VolvoWill Posted January 5, 2008 Author Report Share Posted January 5, 2008 Thanks guys I am going to try replacing the alternator and hopefully its as simple as that. If thats not it I guess I will just try a new wiring harness. Hopefully it goes good if it doesnt I guess I will just have to start swapping it into the 240. (which the that project is way over my head) Link to comment Share on other sites More sharing options...
lookforjoe Posted January 5, 2008 Report Share Posted January 5, 2008 Thanks guys I am going to try replacing the alternator and hopefully its as simple as that. If thats not it I guess I will just try a new wiring harness. Hopefully it goes good if it doesnt I guess I will just have to start swapping it into the 240. (which the that project is way over my head)Aren't the 240 bat terminals on the reverse sides of the battery - I seem to recall the + terminal being close to the fender..... Link to comment Share on other sites More sharing options...
