randomdude Posted February 19, 2010 Report Share Posted February 19, 2010 that should work fine matt. Quote Link to comment Share on other sites More sharing options...
Johann Posted February 19, 2010 Author Report Share Posted February 19, 2010 Broke the 100 mph barrier today.. :pizza: Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted February 20, 2010 Report Share Posted February 20, 2010 That's quite a project. The COP just didn't work out, I take it. Nice fabrication work on the pedal & throttle adaptors. Any screen shots of your fuel management software? I'm just curious if it looks anything like the TurboTuner maps. The engine bay certainly looks quite proper! Update, Lot of things have happened but not much progress has been made unfortunately.. Converted the engine to COP direct spark ignition and sequential injection but it never ran properly. Also changed to Alpha N because this engine shows short tempered MAP behavior. Acceleration needs some attention. Made a new AFR map based on numbers logged and smoothened the whole map which already showed an improvement. If accel plays nice I want to try the quick tune function tomorrow to automatically set some points in the fuel map to the proper values based on a lambda target map. Already used this function before but to make it work fast enough the fixed fuel map needs to be close to the desired values. If all plays nice I think it will show if there is some grunt in this engine. Or bettter said, if it performs how it sounds, Quote Link to comment Share on other sites More sharing options...
Johann Posted February 20, 2010 Author Report Share Posted February 20, 2010 That's quite a project. The COP just didn't work out, I take it. Probably something to do with the trigger sensor setting but if the software says everything is OK and it won't run it is very difficult to gat a bit of a base line and keep the engine running. Once it it running it is easier to see where something might go wrong. Any screen shots of your fuel management software? I'm just curious if it looks anything like the TurboTuner maps. These are from the link site, Software is called PClink. Overview, Fuel map, Numeric runtime values, 3d map representation, Gauges, Logging, And the Quicktune function where the wideband can fill the fuel map based on a AFR target map, Quote Link to comment Share on other sites More sharing options...
TFIVEM Posted February 20, 2010 Report Share Posted February 20, 2010 thats awesome! great progress as always Quote Link to comment Share on other sites More sharing options...
Johann Posted February 20, 2010 Author Report Share Posted February 20, 2010 Small video clip part throttle up to ~5000 RPM. Quote Link to comment Share on other sites More sharing options...
Young Burnsy Posted February 20, 2010 Report Share Posted February 20, 2010 sweet Quote Link to comment Share on other sites More sharing options...
Johann Posted February 23, 2010 Author Report Share Posted February 23, 2010 Limiter test, Quote Link to comment Share on other sites More sharing options...
Emiel Posted February 23, 2010 Report Share Posted February 23, 2010 :tup: :tup: Quote Link to comment Share on other sites More sharing options...
gdizzle Posted February 24, 2010 Report Share Posted February 24, 2010 Sounds really nice Johann! Quote Link to comment Share on other sites More sharing options...
Johann Posted February 25, 2010 Author Report Share Posted February 25, 2010 Sparco passenger seat installed, Driver seat will be installed sometime in the coming week because first it needs new upholstery. Ordered a rebuild set from Sparco and after three months it finally arrived. Quote Link to comment Share on other sites More sharing options...
cr854r Posted February 26, 2010 Report Share Posted February 26, 2010 4 point???love the seat choice Quote Link to comment Share on other sites More sharing options...
Johann Posted February 26, 2010 Author Report Share Posted February 26, 2010 4 point??? love the seat choice This is 4 point yes. Maybe a 6 point will be used for the driver side but the seat is mounted on sliders and the frame has a cross bar which is a bit in the way of the 6 point floor mountings. Quote Link to comment Share on other sites More sharing options...
JoshV70 Posted February 26, 2010 Report Share Posted February 26, 2010 :tup: Quote Link to comment Share on other sites More sharing options...
Johann Posted February 28, 2010 Author Report Share Posted February 28, 2010 Quote Link to comment Share on other sites More sharing options...
