The Chronicles Of Area 34, formerly 55
  • 2 weeks later...
Update,
Since the OEM alternator bracket didn't fit anymore decided to change the already finished motor mount and add some connections for the alternator and the pulley bracket.
Measurements were copied from the OEM mount The motor mount itself is in place of where the AC pump normally is mounted.
Also made a gearbox mount using most of the parts of the Borg Warner AT mount. Because the whole combo is shorter compared to the V8-BW and also mounted lower in the chassis I decided to sort of brace it in to place. No fancy curvy artwork at the moment.
The M90 mount,
The "Brace"
And the mount as it currently is fitted,
Will make something smoother at a later time. For now it is strong enough to do the job.
ME7 intake with 850 TB and idle motor.
Part of the downpipe,
Alternator and tensioner fitted,
  • 3 weeks later...
Update,
With most of the big changes finished the progress appears to be lesser by the day.. :(
Lots of things done which can hardly be noticed.
Had issues with the placement of the shifter shaft in relation to a cross bar in the chassis. Gave me a huge headache. Couldn't really picture the whole setup so I decided to cut a part out of the floor and just start fabricating something to get a bit overview of the whole situation.
Many hours and lots of fun wit the CNC milling machine later something had materialized although a tad over engineered.. :blush:
But it works for now.
Had the drive shaft lengthened, 120 mm, and it fits like a glove.
Decided to use a Saab intercooler for now,
It looks pretty stealth IMO.
Something less stealth,
Made a dummy "steering pump" using an old Unorthodox underdrive crank pulley to maintain the stock belt routing and to make use of the stock belt tensioner.
Used a 5PK1230 belt instead of a 6PK because the only load is the alternator.
Exhaust is mostly done. 2.5" turbo back with a stock Volvo S60 T5 midpipe section including silencer or muffler or whatever it is. Hope it sounds truck like. :tup:
13G plumbing all in place except for one coolant hose. Still need to make a connection for the heater and the turbo to the main coolant pipe.
Although many hardware changes still need to be done I decided to install most of the ECU wiring this week. This because I can't make up my mind which way to route everything and with all the wires connected to the engine I hope it will show which routing will be better. Also thinking about relocating both battery's. There's a main battery plus a battery for the wrench and I think it will be nicer to mount them side by side underneath the cabin.
This seems like a needlessly complicated/ugly solution.
I was in the same position when I swapped a B5234T in my 242. I just removed the idler and shifted the tensioner down:
I re-used the top power steering mount hole and drilled a new hole above the alternator.
Anyway, this looks like an awesome project. You always do very nice work and it's a pleasure to see your updates.
Coming along!
Are you using a Volvo EMS, or standalone?
PS, for making the engine work I decided to use the Link ECU which was in the C30.
The C30 will receive a newer type Link G4 Xtreme standalone.
Talking about the C30, Also received a Bell intercooler for the C30 ,
Very nice quality. Size is 600w x 140h x 110d
What kind of belt did you use?
  • 2 weeks later...
Slowly progressing.
The engine ECU wiring is finished. Finding a nice route was the hardest part because despite the size of the car there isn't that much room to hide stuff. Wiring now runs from the back of the engine underneath the driver side through the wheel well in to the cabin the underneath the dash to the center console. Only have one picture of the engine side loom before is was soldered to the ECU side of the loom,
Like mentioned the engine will use COP's because there isn't space for a distributer at the back of the engine.
The head used on this engine doesn't have all the COP bolt holes present and is missing one bolt hole for the COP ground wires. Cylinder number 1 doesn't have a bolt hole for whatever reason but it did have a larger casted in hole at that spot. Threaded the hole managed to fabricate a small adapter thingy part to make it work. Also because this engine has some ridges with two bolt holes casted in for the old style upper engine mount the cylinder 5 coil needs to be rotated.
Not really happy with the outcome because it will be difficult to fit a cover.
Picture shows vent hose running between cylinder 1 and 2 but has been replaced with a type which runs between cylinder 2 and 3 now.
Connected for this setup,
Crank trigger
Cam trigger
MAP
IAT
TPS
CLT
TCV
Knock1
Knock2
Idle control valve
Wideband oil pressure sender
5 x injectors
5 x coils
Engine will be running full sequential.
Hope to finish the wiring in the coming week. Relay/Power still needs to be done. Also dash needs to be changed but didn't look in to that yet.
Had a couple of fuel lines made,
Exhaust needs hangers.
Lambda still needs to be placed but a local tuning shop lost their wideband while having a car on the dyno and asked if they could borrow mine for the coming days, hope to have it back this week so it can be installed.
In the mean time..
Killed a beemer :P
Spring time sunshine, took a couple of pics of the cars,
Attended a Volvo meeting yesterday but didn't have a running or road legal Volvo available so I decided to show up with some Volvo parts instead,
And someone asked about the SD7's progress...
Well.. Not much ;)
Isn't your throttle cable pointing the wrong direction? To the front of the car?
The alternator mounting and the belt tensioner of the early v70 also fit without modification.
Anyway, I like your manufacturing skills!
Guest
Reply to this topic...
  Only 75 emoji are allowed.
