Johann Posted March 29, 2011 Author Report Share Posted March 29, 2011 True, the throttle cable is running to the front of the car because the firewall is more or less above the engine. I think the throttle pedal itself is only 10" above the throttle body to the cable runs from the pedal out to the front and back to the TB. Quote Link to comment Share on other sites More sharing options...
Johann Posted April 5, 2011 Author Report Share Posted April 5, 2011 Found a place for the oil cooler, Because half of the cooler is situated behind the radiator I baked a duct to lead cool air underneath the radiator, With the radiator in place, Quote Link to comment Share on other sites More sharing options...
Johann Posted April 7, 2011 Author Report Share Posted April 7, 2011 Added 20", BBK front and rear and airride.. And then I drove back to reality .. :huh: 9 Quote Link to comment Share on other sites More sharing options...
sconeman Posted April 7, 2011 Report Share Posted April 7, 2011 (edited) Added 20", BBK front and rear and airride.. And then I drove back to reality .. at first I was like then I was like nice Pshop Edited April 7, 2011 by sconeman Quote Link to comment Share on other sites More sharing options...
Spanky Posted April 7, 2011 Report Share Posted April 7, 2011 Added 20", BBK front and rear and airride.. And then I drove back to reality .. :lol: :lol: Quote Link to comment Share on other sites More sharing options...
Johann Posted May 1, 2011 Author Report Share Posted May 1, 2011 Update, Opel. Engine bay should be functional now except for a few loose bolts left and right. Used the over the engine turbo pipe of the former V70R GT3071 setup. Making the Saab IC fit was a bit of a bitch. Intake, idle valve came out pretty neat although a tight fit. IAT sensor still needs to be wired in. Gas tank turned out to be a disappointment. Need to add some connections for pump and return. Took the tank from the car and after drying in the sun some shaking resulted in this, Looks like some de rusting and coating is needed. C30, Caught a cold, stayed near home for the last couple of days and got bored so I worked on the C30 a bit instead of the Opel. Radiator, brackets, hoses and fan are all new T5 spec. Fit's 1:1. Clutch hydro line from a V50 2.4 fits the M56 1:1 Driveshafts are in, Test fitted the downpipe with a 100 CPI cat and a part of the catback. No end part yet. Bell IC mounted and fits nicely, Installed some parts from the ATP kit and all I can say is that it sucks hugely. Although everything bolts on it is tight. To tight IMO. Coolant lines touch the wastegate dump pipe. Turbo coolant line it way to close to the manifold, turbine housing and exhaust pipe. BOV recirculation looks nice on the website but I really don't have a clue how they mounted it that way because it runs straight in to the turbine housing.. Needs a lot of adaption. Long way to go, bay still a big mess, Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted May 2, 2011 Report Share Posted May 2, 2011 Looks like you've been a busy fella! This looks terrible - .... and is typical of the fitment of the ATP parts, you're saying... The C30 is about the only new Volvo I would consider owning, the rest are too bloated. I like the idea of the ATP bolt-on kit, but it would seem it's really not... :lol: Quote Link to comment Share on other sites More sharing options...
Johann Posted May 3, 2011 Author Report Share Posted May 3, 2011 The C30 is about the only new Volvo I would consider owning, the rest are too bloated. I like the idea of the ATP bolt-on kit, but it would seem it's really not... No, at least not for me. Maybe people are running the setup this way ? Changed the connections on the water pipe. Will be using a hard line for the water. Means the heater hoses need to be changed also. Didn't install the M56 shifter cables yet so I don't know how close those will run to the wastegate dump pipe. Quote Link to comment Share on other sites More sharing options...
Asko Posted May 3, 2011 Report Share Posted May 3, 2011 Nice progress! Do you have a detailed photo or drawing of your gear shifter? I am experiencing some troubles with the space for the M90 gear shifter in the my Opel and yours really looks fit for small spaces. Quote Link to comment Share on other sites More sharing options...
Johann Posted May 3, 2011 Author Report Share Posted May 3, 2011 Nice progress! Do you have a detailed photo or drawing of your gear shifter? I am experiencing some troubles with the space for the M90 gear shifter in the my Opel and yours really looks fit for small spaces. It's bulky.. This is the rough sketch. Make sure the shifter shaft runs straight out of the box. If at an angle it won't shift very smooth. Edit: Keep in mind that with the Blitz the shifter is more or less above the gearbox. Vertically it is situated between the gearbox housing and the driveshaft flange. Quote Link to comment Share on other sites More sharing options...
Johann Posted May 10, 2011 Author Report Share Posted May 10, 2011 Tank was way to rusted to reuse so I decided to buy a new tank. Found a nice classic looking tank at a truck shop nearby. Tank itself was cheap but after ordering the mounting brackets and fuel pickup and sender unit with it is wasn't so cheap anymore.. Some semi gloss black spray paint later, Fitting the tank to the chassis wasn't that hard, Made some hard fuel lines and a couple of brackets to fix them, Only issue was the filler opening, Cutting the load deck and some welding solved the issue, 4 Quote Link to comment Share on other sites More sharing options...
matt b Posted May 10, 2011 Report Share Posted May 10, 2011 Impressive work as always Johann! I wish I had your fab skills. Quote Link to comment Share on other sites More sharing options...
flyfishing3 Posted May 10, 2011 Report Share Posted May 10, 2011 Impressive work as always Johann! I wish I had your fap skills. WATTTTTTTTTTT little personal there matt. 7 1 Quote Link to comment Share on other sites More sharing options...
matt b Posted May 11, 2011 Report Share Posted May 11, 2011 WATTTTTTTTTTT little personal there matt. You have too much free time Mike! Quote Link to comment Share on other sites More sharing options...
Johann Posted May 16, 2011 Author Report Share Posted May 16, 2011 far from finished but, 6 Quote Link to comment Share on other sites More sharing options...
