Seagrams Posted February 26, 2008 Report Share Posted February 26, 2008 MOAR PICS!!!!!!!!!!!!! lemme see!!!!!! Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted February 26, 2008 Author Report Share Posted February 26, 2008 Hey Congrats on getting it up and running!The M66 in my S40 runs about 3000 rpm at 80 mph in 6th gear so 2600 at 70 seems about right. Which shifter did you use? One from an R or from an S40? (Not a big fan of the moonball from the R personally).Did you change out the angle gear oil while you were under there and had things taken apart?I used the shifter from an '00. I need to modify or replace the knob. Didn't want the spaceball, even if it could have been made to fit the console.The angle gear was only installed a few of months ago - so the fluid is fresh - I did reseal it this time, the inner seal was seeping, the outers where dry, but I don't want to pull it again anytime soon.I'll get pics up later today. Quote Link to comment Share on other sites More sharing options...
NEU Posted February 26, 2008 Report Share Posted February 26, 2008 No Joes this time - I just didn't have enough time to play around on this job. Oh Boo.... Well maybe pictures without would be OK... :lol: Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted February 26, 2008 Author Report Share Posted February 26, 2008 Here's some pics of the job... out with the old... in with the new... Pedals & master modified shifter cable bracket forks... ball studs removed & replaced with bolts - I'll be using a cut down shouldered bolt for the final setup - just to make sure the inner wall isn't chewed up by the threads over time... Trans & clutch slave/throwout bearing ready to go in... Angle drive resealed... S60R dual mass flywheel, new Pressure plate & disc... new rear main seal (only 30K on the original clutch that came with the flywheel, but the previous owner clearly had poor clutch control skills...) Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted February 26, 2008 Author Report Share Posted February 26, 2008 Forgot to add the shift knob mod - I checked @ the dealer, and new knobs for the '00 in wood or leather run 87 bucks - the '04 versions run 120... So, I covered the existing with some red leather... heated, stretched & bonded in place... trimmed excess & tucked back into body . all set to go... back in the car... color cast is off due to flash.... Quote Link to comment Share on other sites More sharing options...
FastWagon95 Posted February 26, 2008 Report Share Posted February 26, 2008 Congrats man, thats awesome. I'm impressed you did it in so little time. Quote Link to comment Share on other sites More sharing options...
B Mac Posted February 27, 2008 Report Share Posted February 27, 2008 XC70R Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted February 27, 2008 Author Report Share Posted February 27, 2008 XC70RThat's what I should call it? Sounds good... Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted February 27, 2008 Author Report Share Posted February 27, 2008 Congrats man, thats awesome. I'm impressed you did it in so little time.It took me 10 hours Saturday, and the same Sunday - Seamus did his in less than half, so I was thinking I was kinda slow..... ;) Quote Link to comment Share on other sites More sharing options...
B Mac Posted February 27, 2008 Report Share Posted February 27, 2008 and it took me, Big Will, RWagon, Project volvo, Shellie and OrleeC 3 days....pshhh you're like superman Quote Link to comment Share on other sites More sharing options...
Seagrams Posted February 27, 2008 Report Share Posted February 27, 2008 It took me 10 hours Saturday, and the same Sunday - Seamus did his in less than half, so I was thinking I was kinda slow..... you are my hero :rolleyes: Quote Link to comment Share on other sites More sharing options...
NEU Posted February 27, 2008 Report Share Posted February 27, 2008 XC70RYeah that is better then IPD xc70R they made years ago... But there was the that nice copper color with a R front bumper. Quote Link to comment Share on other sites More sharing options...
Y2kV70R Posted February 27, 2008 Report Share Posted February 27, 2008 All I can say is WOW!!!!!!! I may e bugging you very shortly about this.I too will be doing my own work. I assume you had a full blown shop to work in? Quote Link to comment Share on other sites More sharing options...
Big Will Posted February 27, 2008 Report Share Posted February 27, 2008 All I can say is that I'm impressed. I can't wait to see the in person. You should come up to the Rein's Deli meet on the 22nd and/or the meet down on Long Island on the 15th (The food will probably be better at Rein's ) Quote Link to comment Share on other sites More sharing options...
Seagrams Posted February 27, 2008 Report Share Posted February 27, 2008 All I can say is that I'm impressed. I can't wait to see the in person. You should come up to the Rein's Deli meet on the 22nd and/or the meet down on Long Island on the 15th (The food will probably be better at Rein's )where's the meet on LI? Quote Link to comment Share on other sites More sharing options...
