silverst5 Posted October 18, 2005 Report Share Posted October 18, 2005 What a great Thread!!!! I have a 97 850 t-5 Wagon and did the hole thing in under one hour. When i smeled the coolant I was so pissed of i would have to take the dash apart. Thanks for the great thread and pics.Eddie :D Link to comment Share on other sites More sharing options...
Modus Posted October 20, 2005 Author Report Share Posted October 20, 2005 Nice... Glad to see this is a help.With my change out, (a little over a year ago) and the new one installed, I smell coolant every now and then comming from my vents when the heat is first turned on, then it dissipates and the smell is gone. I first thought that it could possibly be the O rings on the intake and return lines, or maybe a leak that showed up. So i took the whole thing apart a few months back and found nothing. I replaced the O rings with new ones. So that situation won't be a problem.But still smell a hint of sweet glycol for the first 5 seconds. why is this? Should I put activated carbon in my vents? Link to comment Share on other sites More sharing options...
Guest Mel Posted January 6, 2006 Report Share Posted January 6, 2006 Is the process similar for a 2001 V70 XC? I get a little whiff of coolant from time to time when the heat first comes on.keefus Just found this forum today love it! I have a question will this replacement Method will it work on my 1996 850 Gt? I had replaced a little anti frezze one time back in the summer when my coolant light came on, no more problems since. Until I turned my heater on this winter and smell anti freeze, it would go away rather quickly . I would also ocasionally hear my heater fan squeaking when I turned it on and it too would go away fairly quickly? I Thought maybe my blowers fan was going bad but it woked! Then today it all came together turned on my heater the blower fan noise was louder, sounded like somthing was hitting heater fan as it was spinning, looked over at passenger side and see anti frezze on top of carpet! After reading this post Iam thinking heater core and blower! Hopefully this replacement method can be used on my 1996 850 Gt . If so can I change the blower if need? Is it in the same area? Any advise is welcomed! Thanks in advance Mel Link to comment Share on other sites More sharing options...
WhiteT5 Posted January 6, 2006 Report Share Posted January 6, 2006 Just found this forum today love it! I have a question will this replacement Method will it work on my 1996 850 Gt? I had replaced a little anti frezze one time back in the summer when my coolant light came on, no more problems since. Until I turned my heater on this winter and smell anti freeze, it would go away rather quickly . I would also ocasionally hear my heater fan squeaking when I turned it on and it too would go away fairly quickly? I Thought maybe my blowers fan was going bad but it woked! Then today it all came together turned on my heater the blower fan noise was louder, sounded like somthing was hitting heater fan as it was spinning, looked over at passenger side and see anti frezze on top of carpet! After reading this post Iam thinking heater core and blower! Hopefully this replacement method can be used on my 1996 850 Gt . If so can I change the blower if need? Is it in the same area? Any advise is welcomed! Thanks in advance MelBlower motor is sort of in the same area, but is a completely different (and much easier) procedure than heater core replacement, so no it wouldn't really be any easier to do them both at the same time. Link to comment Share on other sites More sharing options...
the underlørd Posted January 6, 2006 Report Share Posted January 6, 2006 Yo Mel. register up! ps - i just put this in the pinned topic for "useful links to repairs" Link to comment Share on other sites More sharing options...
Guest Guest Posted January 7, 2006 Report Share Posted January 7, 2006 Yo Mel. register up! ps - i just put this in the pinned topic for "useful links to repairs"Thanks for the welcome and quick response! Will do just that! just one more quick question Ha! before I do here"s a parcel post by a member name Beecnut regarding the blower assembly replacement..............."just have to remove the lower passenger kick panel, the knee bolster, five or six screws on the motor, one screw on the resistor, some electrical connectors to pull of the motor, and you're done http://www.volvospeed.com/Pics/repairpics/pdash3.jpg"This pic is not the greatest is there any other pic or instruction how to replace the blower assembly? Is this where mines is located? Also would it be easier to relace whole asembley or just motor .I don't have climate control as this example has,is this resistor recomended to replace? For other reading this post I have a 1996 850 Gt no climate control 174,000 wonderful miles. I am changing the heater core and blower motor... I want to oder all part asap from Groton...They have great price bye bye dealer! If you could help with what part to order it would be appreciated ! Mel Link to comment Share on other sites More sharing options...
Guest Guest Posted January 7, 2006 Report Share Posted January 7, 2006 Thanks for the welcome and quick response! Will do just that! just one more quick question Ha! before I do here"s a parcel post by a member name Beecnut regarding the blower assembly replacement..............."just have to remove the lower passenger kick panel, the knee bolster, five or six screws on the motor, one screw on the resistor, some electrical connectors to pull of the motor, and you're done http://www.volvospeed.com/Pics/repairpics/pdash3.jpg"This pic is not the greatest is there any other pic or instruction how to replace the blower assembly? Is this where mines is located? Also would it be easier to relace whole asembley or just motor .I don't have climate control as this example has,is this resistor recomended to replace? For other reading this post I have a 1996 850 Gt no climate control 174,000 wonderful miles. I am changing the heater core and blower motor... I want to oder all part asap from Groton...They have great price bye bye dealer! If you could help with what part to order it would be appreciated ! Mel Hey tried several time to register but the number verfication just renews itself...Is that right? did not get you will receive a email response or anything ...Help again...Mel Link to comment Share on other sites More sharing options...
Guest Guest Posted January 7, 2006 Report Share Posted January 7, 2006 Hey tried several time to register but the number verfication just renews itself...Is that right? did not get you will receive a email response or anything ...Help again...MelTried logging in again and it tells me my email is in use by a member but still having login problem can the Admin Help by sending me an email with password and log in name Thanks Mel Link to comment Share on other sites More sharing options...
Mcsee Posted January 7, 2006 Report Share Posted January 7, 2006 Tried logging in again and it tells me my email is in use by a member but still having login problem can the Admin Help by sending me an email with password and log in name Thanks MelOkay it was my broswer security setting I am now finally registered as Mcsee...Yea! Link to comment Share on other sites More sharing options...
Mcsee Posted January 7, 2006 Report Share Posted January 7, 2006 Okay it was my broswer security setting I am now finally registered as Mcsee...Yea!Ready to tackle heater core replacement ...but from pics could not see why the glove compartment liner needed to be removed and those two screw losen? Okay I ask a lot of question but I am a newbie. Link to comment Share on other sites More sharing options...
beachnut Posted January 7, 2006 Report Share Posted January 7, 2006 Ready to tackle heater core replacement ...but from pics could not see why the glove compartment liner needed to be removed and those two screw losen? Okay I ask a lot of question but I am a newbie. The glovebox liner does not need removed for either the core or the motor job, and yes that pic is from an 850 so your car looks just like it. Link to comment Share on other sites More sharing options...
Mcsee Posted January 8, 2006 Report Share Posted January 8, 2006 The glovebox liner does not need removed for either the core or the motor job, and yes that pic is from an 850 so your car looks just like it.Thanks Beachnut for your reply got parts on order! but the two screw need to be lossen for the kickpanel to be release for the blower job right? Link to comment Share on other sites More sharing options...
Mcsee Posted January 16, 2006 Report Share Posted January 16, 2006 Thanks Beachnut for your reply got parts on order! but the two screw need to be lossen for the kickpanel to be release for the blower job right?Got parts great instruction and pics Job done ...Thanks To All! ;) Link to comment Share on other sites More sharing options...
out-door-man Posted February 24, 2006 Report Share Posted February 24, 2006 Just replaced the heater core on my V70 with the aid of your site. So easy its untrue. Got heater core off e-bay for £100 not £240 + vat from Volvo. Fits fine and works OK. Thanks for the help. By the way the glove box DOES need removing for a V70 otherwise you can break the supporting tags for the parsel shelf. Be warned. Link to comment Share on other sites More sharing options...
98V70BASEBOY Posted February 24, 2006 Report Share Posted February 24, 2006 Just replaced the heater core on my V70 with the aid of your site. So easy its untrue. Got heater core off e-bay for £100 not £240 + vat from Volvo. Fits fine and works OK. Thanks for the help. By the way the glove box DOES need removing for a V70 otherwise you can break the supporting tags for the parsel shelf. Be warned.Left hand steering does not require removal of GB. Right hand, perhaps. Link to comment Share on other sites More sharing options...
