tdo4hl-16t Turbo Swap
YouGot5Banged
Hey so recently have had my TDO4HL-13G start leaking oil and having shaft play it is time for a new turbo so I want to upgrade I have a 2002 Volvo xc70 (Engine: B5244T3) I am heading to a local wrecking yard (Pull N Save) I was wondering from what year and model VOLVO TDO4HL-16T is a straight bolt up to my 2002 volvo xc70
  • 2 weeks later...
  • Similar Content
    • By YouGot5Banged
    • By Mustapha
      Hello,
      first time posting here not sure what to expect. So I have an 07 xc70 I recently purchased and have a few questions about some performance mods I would like to do. So this car has about 175k miles and I want to boost my horse power up to the high 200’s if not low 300’s it’s my daily and I want a bit more juice for fun but I don’t want to destroy it too bad I love the i5 sound and the entire car in general. What are some things I can do to increase the horsepower but keep it from killing itself. Also what are some good exhaust mufflers or kits I can buy that increase the sound at higher rpms but not as much at low rpms it just sounds so amazing at high revs and I want to emphasize that as I’m driving. Any feedback or suggestions would be great. Thanks!
    • By mynewvolvoexp
    • By Figawi
      Hi,
      I have a 2010 S80 and the volume/power button for my radio no longer lights up at night. The part number for the control unit is 30782904. I'm wondering if the button contains the bulb or whether the bulb is replaceable/fixable? Button part number is 31288750. The rest of the unit lights up just fine. If I need to replace the whole control unit, can a used one be programmed to work in my car or does it have to be new? I've heard mixed answers.
      This unit is also found in V70/XC70s in 2010.
    • By Zypher
      Looking to start modding my 2004 XC70 for a more offroad leaned build.  She is up to date on the 150,xxx mile checkup with no red flags.  Front shocks/struts  need to be replaced soon however so I got the idea to start putting a more offroad setup onto the car.  Not going to go 100% lifted crawler madness, just looking for a bit of lifting, engine tuning, and performance modifications. Plus with the crazy ALL GLORY TO THE HYPNOTOAD winter we had in the PNW I'm sure that this would only help in snowy years to come. The question I have is where do I start? Been looking at various lift kits and suspension/strut setups as well as ECU tunes from IPD and Evolve but want to hear what you guys have done.  Thanks in advance for any helpful answers - cheers!
