I have the engine code 'p0016 crankshaft position - camshaft position correlation bank 1 sensor A' which usually relates to timing. The car came with this code but had a terribly damaged water pump which would have loosened the belt somewhat. I replaced the water pump and lined up the timing marks.
The code still exists and the car runs poorly at certain revs/ speeds (vibration) and is thirsty. Doing some research I think I didn't load the exhaust cam spring properly so even though the mark is right the cam could be a tooth or 2 off.
If that is the case to retime it do I need to buy a cam lock or can I load it but turning anticlockwise then clockwise or vice versa.
Rigs
