blazen244 Posted August 22, 2008 Report Share Posted August 22, 2008 :o How hard is it going to be to change out the PCV and do I have to get under the car ,will ramps work or need a left Link to comment Share on other sites More sharing options...
early_november Posted August 22, 2008 Report Share Posted August 22, 2008 How hard is it going to be to change out the PCV and do I have to get under the car ,will ramps work or need a leftRead this, http://www.lakesidedp.com/uploadpics/pcv/ Then decide if it is something you can tackle. Ramps would be fine. Link to comment Share on other sites More sharing options...
Oreo931 Posted August 22, 2008 Report Share Posted August 22, 2008 Not sure why you need to get under the car to do the PCV replacement.I have done mine 3 times (long story).First time took me a long long time (6-8 hours?).Second time took me 2.5 hours, 3rd time took me 1.5 hours. Link to comment Share on other sites More sharing options...
jazzyjeff Posted August 22, 2008 Report Share Posted August 22, 2008 Here's an article by Zimbo on the procedure:http://lakesidedp.com/uploadpics/pcv/And here's a thread that he made that answers some more questions about the job:http://volvospeed.com/vs_forum/index.php?showtopic=89543 Link to comment Share on other sites More sharing options...
blazen244 Posted August 22, 2008 Author Report Share Posted August 22, 2008 Wow thats a lot can anybody give me a hand this weekend Link to comment Share on other sites More sharing options...
Keaton85 Posted August 23, 2008 Report Share Posted August 23, 2008 Wow thats a lot can anybody give me a hand this weekendIt's extremely simple, it just looks like a lot on paper. Link to comment Share on other sites More sharing options...
sconeman Posted August 23, 2008 Report Share Posted August 23, 2008 be prepared to scrape your knuckles taking off the manifold and dipstick brackets. Get yourself a magnetic 10mm wobble, and a magnet wand for when you drop the passenger side 10mm bolt down between the alternator and the block. then you'll be all set. Link to comment Share on other sites More sharing options...
Keaton85 Posted August 23, 2008 Report Share Posted August 23, 2008 be prepared to scrape your knuckles taking off the manifold and dipstick brackets. Get yourself a magnetic 10mm wobble, and a magnet wand for when you drop the passenger side 10mm bolt down between the alternator and the block. then you'll be all set.You dont need to remove any of the lower 10mm bolts on the manifold, which saves you from dropping any of them.You dont even need to remove the manifold from the car even. Link to comment Share on other sites More sharing options...
sconeman Posted August 23, 2008 Report Share Posted August 23, 2008 You dont need to remove any of the lower 10mm bolts on the manifold, which saves you from dropping any of them.You dont even need to remove the manifold from the car even.the lower bolts yeah. but the other ones drop just fine hmmm I'm trying to envision how to do it without taking off the manifold. I think the first time around you'd have to take it off otherwise you'd have no idea what what goes where. Link to comment Share on other sites More sharing options...
