Matts 850 GLT Posted September 12, 2005 Report Share Posted September 12, 2005 Hi VSI got a new start problem the last few days.After a long run at high speed I switch off, when I come to restart the car 10 mins later it cranks and cranks then eventually stumbles and fires. After a blip of the throttle it holds idle just like normal.It can crank up to 10 seconds before firing. Doesn't do it when its cold. No codes.Hope you can helpThanksMatt Link to comment Share on other sites More sharing options...
shurgen Posted September 12, 2005 Report Share Posted September 12, 2005 Hi VSI got a new start problem the last few days.After a long run at high speed I switch off, when I come to restart the car 10 mins later it cranks and cranks then eventually stumbles and fires. After a blip of the throttle it holds idle just like normal.It can crank up to 10 seconds before firing. Doesn't do it when its cold. No codes.Hope you can helpThanksMatt←Matt, read this thread, you may want to try using seafoam: http://volvospeed.com/vs_forum/index.php?showtopic=20144 Link to comment Share on other sites More sharing options...
Matts 850 GLT Posted September 15, 2005 Author Report Share Posted September 15, 2005 HiI have not come across seafoam in the UK yet? Perhaps it will get here soon.Anyway the problem has got worse and now at high speed and when the car is hot it will cut-out when I come off the throttle. It did this quite a lot yesterday. Gotta pull over and wait to re-start it!!I took out my plugs last night and the tips seemed clean but the white ceramic part was cracked on one plug and was dark brown on the others.So I put new plugs in last night and went for and 'italian tune-up' so far so good, no cutting out and no issues with restarting.Hopefully the plugs have cured it - but I wonder what made the other set go bad?Matt Link to comment Share on other sites More sharing options...
James A Sousa Posted September 16, 2005 Report Share Posted September 16, 2005 Check your plugs every 500 miles and see what they do. If the same thing happens, seek professional help.Thank your lucky stars that the plug did not break and hole your piston. This is one reason NOT to do an Italian tune-up until you find out what the problem is!Let us know what happens. Link to comment Share on other sites More sharing options...
