Mark in Austin Posted July 17, 2007 Report Share Posted July 17, 2007 On hot days, the A/C almost always quits while in city traffic. Research from this forum and elsewhere points to the high pressure sensor. This is an easy fix but an expensive part. Before I chunk down $100 for a part most likely to solve my problem, I'd like to know if there is a way I can test the high pressure sensor.This is a 2000 S70 2.4L non Turbo.Thanks in advance,Mark Link to comment Share on other sites More sharing options...
maiku Posted July 17, 2007 Report Share Posted July 17, 2007 or you could just need a recharge Link to comment Share on other sites More sharing options...
MrWinkey Posted July 18, 2007 Report Share Posted July 18, 2007 Yes actually he might be correct^^^^^^^^ Many times if the charge is low it will work fine but under heavy demand the low charge will cause the evaporator to freeze up resulting in A/C shut down. When it thaws out it will re activate. I would have the charge checked. Link to comment Share on other sites More sharing options...
Rower Posted July 19, 2007 Report Share Posted July 19, 2007 Could be the clutch on the compressor, does it click off when it stops cooling? Check my fix:http://volvospeed.com/vs_forum/index.php?showtopic=80181 Link to comment Share on other sites More sharing options...
