Spdu4ia Posted August 7, 2007 Report Share Posted August 7, 2007 I did search and found a lot of threads but nothing specific to my problem.My S70 blows air but it is hot/warm air. My compressor clicks on and off in 10 second incriments. I put an AC recharger on it and tried to refill it. PSI readings were between 30 and 70 in that 10 second time frame... something like thiscompressor off - 30psi, compressor clicks on - steadily rises to 70 psi - compressor clicks off, and it falls back to 30 - compressor kicks on. (REPEAT)any ideas please (if this is in the wrong section i'm sorry please move) Link to comment Share on other sites More sharing options...
Spdu4ia Posted August 8, 2007 Author Report Share Posted August 8, 2007 Anyone? please? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 8, 2007 Report Share Posted August 8, 2007 It sounds like you are still low on R134 if you are still cycling. How many pounds did you put in? Link to comment Share on other sites More sharing options...
Spdu4ia Posted August 8, 2007 Author Report Share Posted August 8, 2007 It sounds like you are still low on R134 if you are still cycling. How many pounds did you put in?I cycled it for about 15 min on the can and only feels like it took about 1/4 of it. i didn't want to overcharge... should i put it back on? The can said it should take one whole can in about 5 min Link to comment Share on other sites More sharing options...
7 VII 7 Posted August 8, 2007 Report Share Posted August 8, 2007 go get it professionally chargedcould be a issue with the gap in your AC Compressor Clutch... see here Link to comment Share on other sites More sharing options...
Spdu4ia Posted August 8, 2007 Author Report Share Posted August 8, 2007 go get it professionally chargedcould be a issue with the gap in your AC Compressor Clutch... see herewould this still be an option if my a/c never really blows cold? so your saying it may not ever be engaging? Link to comment Share on other sites More sharing options...
Chilled man Posted August 8, 2007 Report Share Posted August 8, 2007 would this still be an option if my a/c never really blows cold? so your saying it may not ever be engaging?i second that ;) Link to comment Share on other sites More sharing options...
7 VII 7 Posted August 8, 2007 Report Share Posted August 8, 2007 well... if never blew cold...get it recharged professionally (mechanic) I recharged mine and it blew cold.. but when i took it in to get it professionally done it was 1/4 full... so I thought it was fine.. but it was not. Link to comment Share on other sites More sharing options...
sixdown Posted August 9, 2007 Report Share Posted August 9, 2007 I have the same issue. My A/C never blows cold air, but the fan works perfectly well. I can't figure out what the problem is, and I still have to get it professionally charged after trying it myself. It didn't get cold after I tried recharging it. Link to comment Share on other sites More sharing options...
MrWinkey Posted August 10, 2007 Report Share Posted August 10, 2007 go get it professionally chargedAgreed....... again it sounds like you are low on freon. Link to comment Share on other sites More sharing options...
PyROTech Posted August 10, 2007 Report Share Posted August 10, 2007 cant hurt since it doesnt blow cold anyways, so if they say you got a problem and jack all the refrigerant then it doesnt matter anyways. Link to comment Share on other sites More sharing options...
